schuie clutch judder.
My car has developed clutch judder but not all the time , if you pull away with the revs slightly up it,s fine but if you dont it judders, the gear change is fine no resistance in any gear, goes in gear easely and reverse,you just need to blip the throttle when pulling away for a smooth take off ,any ideas anybody ps if the clutch is not adjusted proper does this cause it to wear prematurely i e wearing out quicker than it should or is this untrue, my clutch is quite fierce but not heavy and bits near the top it took some getting use to when i first got the car , many thanks regards marino bottali.
