The one and only code for fiat radio thread.
hi
i have lost my r/cd code
the number is
BP - Nr 7 643 331 316
prod Nr fiat 735 391 102
and car s/n zfa16900000061569
can you help me?
Γεια σου Νίκο, Καλώς ήρθατε στο FF.
You have posted the Blaupunkt and Fiat part numbers for your radio.
You also need to post the serial number. For your Multipla radio it will be something like BPX331XXXXXXXX. It may be on the side of the radio.
https://www.fiatforum.com/donations.php
I have lost the radio code of my Fiat 500 (code between 1111-6666).
I managed to pull out the radio:
I think the one you need is:
BP738987093339
however here are the others:
BPnr 7647389316
fiatnr 7354524860
thanks for your help
Yes.... you need to leave the radio switched on permanently for up to 2 hours or until the display shows " CODE " then " ---- ". It shows " WAIT " because someone has tried entering a wrong code too many times.
If the radio set to automatically switches itself off after a short period, you will need to leave the radio and ignition switched on for the waiting time.
I will get in the help line :)
I need help with a code for the radio, data is as follows:
BP7643331316
Prod. Nr. Fiat
735391102
And imprintet in the metal on the radio:
BP333140957936
Thanks,
A.
