The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Please provide me the radio code for my Fiat linea.
The serial number is 815BP8129981782686
bp Nr is 7 648 299 316
Fiat Nr is 735 485 945 0
There are too many numbers in the serial number you have posted. It should be 815BP followed by 12 numbers, not 13.
If you post the correct serial number, then I can get your code.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Please provide me the code first. If it works then no problem in donating to this forum. As i have already lost some amount in getting codes.
Look through the other 5,000+ posts on this thread, you'll see that's not how it works and also that Davren will go out of his way to help if the code doesn't work
Hello,
Here are the details for the radio in my Fiat 500 sport, do you have the code for it?
Code: 7093M120450155
Hello. Can you help? I have a Multipla. Was doing work on engine and disconnected battery now radio code is needed which I don't have. I've attached a photo of the radio details. Happy to donate.
815CM6325A8477103
7646325316
I have the code for your radio.
