You may find this useful (taken from official Dealer manual)
Anti-theft code
The radio is installed in production and is connected to the CAN in order to establish communication with the Body Computer memorizing an anti-theft code known as an Exchange Code.
At each subsequent Key On (and even if the battery is disconnected), an automatic authentication procedure is repeated: the words "CAN CHECK" appear in the radio display: if the Exchange Code check is positive, the system begins to operate. If the codes compared are not the same, a message appears on the display asking the user to enter a manual code (Master Code - 4-figure code from 1111 to 6666) that is shown on the radio code card.
The Master Code is pre-programmed in production and is different for each radio. It is also different from the Exchange Code.
Entering the secret code
When the radio is switched on, if there is a code request, the word "CODE" will appear on the display for about 2 seconds followed by four dashes "----".
The secret code is made up of four digits between 1 and 6, each corresponding to one of the dashes.
To enter the first digit of the code, press the button corresponding to the pre-selection stations (from 1 to 6). Enter the other digits of the code in the same way.
If the four figures are not entered within 20 seconds, the display again shows the message "CODE" for 2 seconds and then the four dashes "----". This is not considered as incorrect entering of the code.
After entering the fourth digit (within 20 seconds), the car radio will start to work.
If an incorrect code is entered, the radio will give out an acoustic warning, the word "CODE" will appear on the display for 2 seconds and then four dashes "----" to indicate that the user needs to enter the correct code.
After three attempts the radio considers the last code as "incorrect"; each time the user enters an incorrect code, the waiting time increases gradually (1 min, 2 min, 4 min, 8 min, 16 min, 30 min, 1h, 2h, 4h, 8h, 16h, 24h) to a maximum of 24 hours. The waiting time is shown on the display with the words "RADIO BLOCKED, WAIT".
After the writing has disappeared it is possible to start the procedure of entering the code again
