Removal
First empty the foam storage of the fix and go kit, and anything else you have hidden under the boot floor!
Now undo the two luggage strap hooks using the hex key. They are sealed to the car floor so may be difficult to turn. Once they are undone you can remove the boot floor from the car.
Now remove the three screws holding in the bottom of the plastic boot lip cover. You do not need to remove the large torque bolt. Pull at the bottom of the plastic to get it over the grey luggage hooks.
With a little careful movement you should now be able to remove the foam insert from the wheel well. Once it's out you'll be left with this!
