attaching the leather
this bit is really hard.. the only proper points are the plastic pegs.. but the leather has holes in it where it was removed from the HGT plastic trim.. i just covered each peg in adhesive, and then found anything i could that was heavy to push the leather down. at this point i had to take it outside cos my parents wanted to use the table..
its quite hard to get the leather attached, so try anything you can.. i tried to get some silicone to try and make more pins like the orignals.. which you can see in the picture.
ive not reattached the trim yet... cos its dark.. but it should look good! it comes away abit from the trim but when its pushed back on, the points behind the leather should push it up against the trim more.
so there we have it! i managed to get the trim and the card off the trim, in under an hour
good luck!!!
