- Remove expansion Tank Cap
- Loosen the Bleed Screw on the RHS of the Radiator and Also the Screw on the heater Matrix Pipe (RHS at rear of block)
- Undo the Jubilee Clip on the bottom of the Radiator Expansion Tank
- Drain Coolant
- Undo the Jubilee Clips on the Left and Right hand sides of the Steel Pipe
- Using a 10mm socket undo the Bolt that supports the pipe (LHS of Manifold)
- Pull pipe free from Water Pump and Remove from behind Manifold
- Clean Hole at Water Pump
- Fit new Part and assemble in Reverse order
