Mounting the antenna
Were nearly there folks!
The foil antenna wont stick to a dirty bumper, so ensure its perfectly clean
It says to wipe down with an alcohol based product, but i didn't have any
On my sporting bumper there were these convenient markings too!
Now to my understanding from the manual, you may wish to disagree or decide to run the full length up-to you
I ran the foil strip between the 2 lines across the length to and from the vertical creases. Simple peel and stick.
Since the wiring will be coming more from the O/S (driver side)
(The kits wires are long enough to sit the unit near the flap and run the antenna wire out)
I put the antenna spade terminal on the driver side too
So All the components are now fitted, just connect it all up
