Putting the Bumper Back On
Line the bumper back up, and connect the 4 cables you left there earlier. Make sure you match the first one to the 'A' cable, the second to 'B'... you get the idea. Also, if you took the rubber washers off earlier, put them back on now.
Cable tie the wires together, and use the two screws you left in earlier to hold the bumper in place.
Plug in all the cables into the box, turn the ignition on, stick 'er in reverse and test the sensors...
If everything is working it will beep once when you put it into reverse, and then beep more if you get close to them. Feel free to go for a drive to test it out, but...
a) don't forget your bumper is held on with 2 screws, not the 10 Fiat designed it with
b) get someone to watch you backing up to whatever you test with; things might not be working properly, and you don't want to end up in a wall!
It it's all working, go back through the earlier steps in reverse to put your bumper back on.
