Re-assembly
Stage 3 - Re-assembly
This is easy:
Remember to ask an adult to supervise, as silicone substances can get messy...
Run a bead of ideally clear silicone (or similar) around the rim of the plastic headlight body. Then, being careful not to smear dirt and stuff inside the lens, push the lens onto the plastic body.
Couldn’t take a photo as hands got too dirty!
As I needed to use the car straight after the repair - I used racer style tape to hold the lens in place - we don’t want it falling off do we. This can be removed the next day (if you want
Then carefully fit the headlight unit and indicator back in place and insert the headlight and sidelight connectors. Replacing the 8mm nut.
There you go - it should be fixed, avoid putting too much force on the adjuster in future – Though it should be as strong as before, if not better.
Well done - you just saved yourself some cash, and the environment! - Respect! Haha
Now go get some
