what does the Alternator Look Like?
Simple like this
Mine is a 2nd hand replacement from a Local Scrap yard - So as you can see they simple cut the wires off
There are also 2 Bolt holes
And 1 Slider Hole
the Slider and the Bolt hole that are level with each other use a Simple Bolt to attach
the Bolt hole that is set back uses a Nut and Bolt
On the Back 2 wires
the thick Red One is the Feed and from the battery
And the black I believe is an earth? I’m not sure but either way
