Tools Used
It’s not a hard Process to change an Alternator so only a few tools used
- A 3/8th Ratchet
- A 17mm 3/8th Socket or 17mm Spanner
- A 10mm 3/8th Socket or 10mm Spanner
- A 8mm 1/4inch socket - Spanner may be hard to fit in but could be used
- A 13mm 3/8th Socket - Spanner may be hard to fit in but could be used
- A 3/8th to 1/4inch socket adaptor
- A 17mm Spanner
- WD40 May come handy, if the bolts haven’t been cracked off before
- Volt-meter/multi meter if you have 1 - not essential though
If the Belt is suspect to been old / cracking / Dry / Shredding, it must be replaced
now is the chance to-do it
If you don’t have a multi-meter, find a local garage that does a free battery and alternator test
Do a test before and after fitting, and the voltages should still apply mentioned later
So On with it we go!
