lamboboss67
- Jan 30, 2013
- 28
- 11
So here's an interesting one for you. I was out today in my GP, it's the 1.2 8v and I was moving along fairly rapidly about 130-140km/h and over 4k rpm when I got a check engine light flashing for a few seconds or so, then it went away and hasn't come back since. I didn't notice anything strange about the car's performance or behaviour, I went to see if I could get a fault code read but garage was closed. So I decided to go out and do a so-called "italian tune-up", gave it some high rev bursts on the open road, then went back to cruising at the same speed and revs as before and it didn't come back. What do you think? Spark plugs were changed about 7k miles ago, timing belt was changed over 20k miles ago.
What I suspect is that it was just an ECU hiccup or some kind of misreading, the reason I suspect this is that a couple of years ago I was cruising at 100km/h (3k rpm) and suddenly the check engine light came on and my temp dial rapidly shot up to hot for a split second, then rapidly went down to normal again and check engine light switched off. I had the car diagnosed and there was nothing wrong with it, obviously was an ECU hiccup since engine temp doesn't rise that quickly. Nothing similar has happened since then until now.
