Trxxjeh
Hey,
So I recently had the problem with my fiat grande punto 1.4 16v from 2009 that the EML light was turned on yellow and the performance of the car was greatly reduced giving error codes p0011 and p0016. I brought it to a garage and they changed the timing belt, solenoid, sensors and many more things. The performance of the car is back to normal.
However, I noticed something weird and that is that the EML light turns on and turns off when I start the car, but if I turn off the car immediately and put it back on contact the EML doesnt turn on until I try again like 15 mins later. Is this normal behavior? Because of this I went to a different garage and checked for error codes and it showed up with p0010 and p0016. So basically the timings are still of, however the EML light doesn't stay on anymore and the performance of the car is back to pretty much normal as far as I can tell.
Is it possible they programmed to EML to function like this or is this how it always works with this car? Should I go back to the garage because the error codes are there even though the car seems to run normal?
