- Oct 11, 2017
- 22
- 4
Hi All,
First and foremost, welcome to my thread and I hope that you are all well?
This is actually my first post, I'm a petrol head with Fiat GP 1.4 TJET, I work full time as an IT Consultant but enjoying spending my time, effort and wages on 'Bumble Bee'.
So, to provide a backbone to my query; when I purchased the car I suffered extreme handling issues. The rear wheel was buckled, the shock absorber was blown and tracking/alignment was out. I've rectified the buckled wheel and tracking/alignment, this weekend I took upon the task to address the suspension. Let me iterate further...
Summary:
I opted to replace all shocks, purchased the Stance+ Kit from Venom Motorsports. Also decided to replace the drop links with shorter ones and fit new top mounts too! So far so good... right? HOWEVER, it didn't last more than thirty second on the first test drive. Drivers side drive shaft popped out, bearings and needle rollers flew out along with gearbox oil.
Issue:
From what I can gather, now that I've lowered the car, it's become apparent that the driveshafts are 'too' short and can't handle the excessive strain.
Solution:
Hopefully you'll agree, but I presume longer drive shafts would rectify the issue as they will sit further in the cup and would then be under less strain. I'd suspect the length in the middle will need to be increased by 230-250mm and reinforced if possible?
At the moment, Plan A of restoring the car on standard shock absorbers, drop links and replacing this an original driveshaft isn't really a solution for me. It'd cost me in the region of £150-£200 and will defeat the purpose of the hours I spent changing them in the first place!
Looking for advice from others which may have experienced the similar issue.
Any other relevant information...
I've attached some photo(s) below for your reference and my vehicle details.
Vehicle Details:
Manafacturer: Fiat
Model: Grande Punto
Year: 2008
Thanks in advance, I look forward to your response(s)!
Summary:
Issue:
Solution:
How did you overcome this issue?
Did you fit the drive shafts yourself?
How much did the resolution cost?
Vehicle Details:
Manafacturer: Fiat
Model: Grande Punto
Year: 2008
