First of all I would like to say hello to everyone, I'm in need of abit of help, I'll start from the top, as per topic title I have just bought my first car its a 2006 fiat punto active sport, I paid £900 with 70,000 miles on clock, it's however needed a new crank sensor wheel balancing and a new temperature sensor,all these have been fixed but there's still a problem with the car, whenever I start it up in the morning it cuts out 3 times, then works perfectly fine, I've been told a couple of things from garage, first thing I was told was throttle body, then I looked around and spoke to a few people and they rarely break as far as I've been told just need a clean here or there, I've also been told it's the ecu causing it to cut out if this is the case why only 3 times and why does it work fine after presumably it would just cease to work? Ecu ive been told is expensive about £800 kind of expensive, I don't really know the first thing about cars but I've been starting to learn does this sound like a serious problem? Did I get ripped off paying £900? The trouble is when you don't know what to look for its rather annoying when things go wrong when you've had it a day, the start up thing didn't happen when intest drove it just the day after
Thanks for all the help in advance
