Technical Dash lights and radio problem
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Morepower
Hi all
I removed the fiat radio and replaced with a kenwood unit with Bluetooth, fit went well except the extra lead supplied by Halfords for the steering controls was the wrong one ? I returned it and they say they only have a listing for the punto for 2006 on and not the GP, not happy so far ? However looking at the multiplug there is only one wire from the car that doesn't have anything allocated on the kenwood ISO plug, could this be the steering control as there is a separate wire on the kenwood with 'remote ' labelled on it, is it as simple as connecting the two?
Also while the radio was out I thought I would change the heater unit bulbs as mine if completely out in the dark, after much looking with a torch and mirror I can't see any bulbs in the back? Confused now unless it's magic or some scorcery that lights it up and the magic just needs topping up ??
Any thoughts greatly appreciated
