cmosfxx Established member Joined Apr 3, 2012 Messages 1,365 Points 263 Dec 12, 2014 #21 Are you sure switch is working ? Check again for open/closed circuit when you press it and check cables again. iirc the correct voltage
OP OP TylerZA New member Parked in the garage Joined Oct 21, 2013 Messages 50 Points 14 Location Pretoria Dec 12, 2014 #22 yeah , tested it the other day, i had a voltage of 6v though.
cmosfxx Established member Joined Apr 3, 2012 Messages 1,365 Points 263 Dec 12, 2014 #23 I really don't know what else can it be. You have to connect at dashboards' ecu and read values/errors.
OP OP TylerZA New member Parked in the garage Joined Oct 21, 2013 Messages 50 Points 14 Location Pretoria Dec 12, 2014 #24 Ok Thanks a lot, will get the dealer to look at it when I take my car in for it's Cambelt.
