jameshobiecat
Established member
- Nov 16, 2010
- 1,945
- 388
I've just replaced the left rear wheel bearing, its quite an easy job so anyone who is capable of changing their discs and pads could do it. In fact, the procedure is basically that of a disc and pad change with the addition of tapping off the bearing cap and undoing the 32mm hub nut, swapping the bearing and tightening the nut. Could be done in under an hour if you cracked on.
