im Axle Specialists
Old 27-04-2014   #1
Jacob has donated!
Wet driver's footwell, please help!!
I discovered both front footwells were soaking wet through a few weeks ago, so I took the seats out removed the carpet and dried it all out thoroughly.
At the same time I bought the longer drain hose for a Mito and installed that and sealed it in place so no water could run down around where it fits in.
I also tigersealed the rusted servo plate so that should now be watertight as the trough is filled and the surface of the plate is covered in tigerseal. I also tigersealed the black plastic cover in place so that should also be waterproof.
Just went outside after a big rainstorm and checked the car - wet through driver's foot well again!!!
I've looked online but all I can see is the servo plate issue which I've already fixed using the guide on here so it shouldn't be that anymore.
Does anyone have any ideas as to where this rainwater is coming from?!
It isn't coolant or ac fluid or anything from the car itself, it's definitely rainwater and the car was parked up so it's not a seam under the car.
If anyone has any ideas that would be great as I'm really lost with this one?!
Jacob is offline Reply With Quote Quote
Old 27-04-2014   #2
Jacob has donated!
Re: Wet driver's footwell, please help!!
Just to add,
the water is underneath the carpet in the soundproofing so it doesn't appear to be dripping down onto the carpet as the top is dry.
You can feel the water by putting your fingers through that plastic sliding bit which has the chassis underneath.
Old 27-04-2014   #3
Mjet220 has donated!
I couldnt suss mine either did the same as you then it turned green, that was the final straw
Mjet220 is offline Reply With Quote Quote
Old 27-04-2014   #4
Jacob has donated!
Quote Originally Posted by Mjet220 View Post
So you did the fix but still got wet carpets?
I'm wondering whether to try and replace the entire plate, massive job I know but rather that than a wet, stinking car.
I just want to check if anyone knew of any where else the water could be coming from :/
Old 27-04-2014   #5
Trader Rating: 2
colin79666 has donated!
Check around the scuttle panel, could be a leak at the base of the windscreen. Ever had it replaced?
colin79666 is offline Reply With Quote Quote
Old 27-04-2014   #6
Jacob has donated!
Quote Originally Posted by colin79666 View Post
As far as I know the windscreen is original but I'm the 4th owner so don't really know, but surely if it was leaking through the screen it would drip on top of my carpet?
The wet is underneath the carpet, the top is dry.
Old 27-04-2014   #7
No no fix i scrapped it, was always wet, the area didnt even look affected by rust or anything but sealed everything anyway
Old 28-04-2014   #8
Jacob has donated!
Oh haha, scrapping would be a bit drastic, it's a good car otherwise, just a bit damp!
Guess it's time to strip it all down again and search for another leak! Sigh.
Hey, at least it'll look like a race car with no carpets
Cheers anyway
Old 28-04-2014   #9
Oh no that was just the final straw after it blew up for the third time
Old 28-04-2014   #10
When you've got the carpet up put a hose on the windscreen so you can see where it's coming from.
jameshobiecat is offline Reply With Quote Quote
Old 28-04-2014   #11
Jacob has donated!
Quote Originally Posted by jameshobiecat View Post
Just took the carpet out again, I'll be a pro at dismantling this car soon.
When I removed the plastic trim from the sills (kickplates?) it was damp underneath them so perhaps the water is coming in through the door seals or window seal and running behind the door card.
I'll get the hose on it and have a look soon.
Old 28-04-2014   #12
Have you checked the brake servo? Common problem, water drips onto it eventually rusting it through causing water to run into the footwell.
http://homepage.ntlworld.com/sinister/GP_Leak.pdf
FiatPuntoMad is offline Reply With Quote Quote
Old 28-04-2014   #13
Could It not be a leeky heater matrix ?
ck247 is offline Reply With Quote Quote
Old 28-04-2014   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by Jacob View Post
Or from door as no garage especially dealerships refit the weathersheetm membrane behind the door card after changing regulator or door lock etc.
Many Fiat cars suffer from poor sealant application around bulkheads, it's not uncommon at all.
Old 29-04-2014   #15
Jacob has donated!
Quote Originally Posted by T14086 View Post
Where would the water actually be getting in in that scenario? The window seals maybe?
(T) Wet footwell Vickster Punto (Mk2/2b) 29 02-01-2013 19:22
(G) Wet drivers footwell clock34 Bravo / Brava 10 09-04-2011 08:26
(G) wet footwell from ac adam79 Punto (Mk2/2b) 5 12-08-2010 09:35
(T) VERY wet driver footwell!! megbravo Bravo / Brava 3 17-10-2009 11:27
Wet footwell in punto and... gorman_bec Lets Talk FIAT 5 10-11-2004 09:15
