I have just had a new clutch fitted, after getting it back the bite point is almost at the floor. Pre clutch fitting it was quite high which is what I was used too. Its a right pain and seems wrong.
The mechanic bled the clutch several times and its still no better. The car is a GP 1.4 8v active sport. The clutch operates fine and is now nice and smooth just far too low a bite point.
Does anyone have any suggestions? I have had a look at the master and slave and there are no obvious signs of leakage and I don't seem to be losing any fluid.
One thing of note, during bleeding the clutch pedal stuck down twice (I helped bleed) and I had to manually lift it. Once bled I have not been able to replicate this.
Could it be a sign the slave is on the way out and needs replacing?
