Old 11-02-2013   #1
rusted connections causing light problems!
One of the four pins on the connection on my back left light is rusted, i've tried scraping the rust off with no luck. Anyway..my back left indicator doesnt work when indicating, instead both red lights flash on the left. And when locking my car, the back right indicator flashes, along with all four red ones! Very annoying. Could anybody confirm that it is the rust doing this as £30 for a new light is pricey if it doesnt work. Thanks. Oh, it's a 1.9 multijet btw
ben0101 is offline Reply With Quote Quote
Old 11-02-2013   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: rusted connections causing light problems!
try an emmery board (nail file) and or bit of emery paper rolled into a tube with the grit to the inside and jiggle up and down on the pin.. and contact cleaner solvent...
(also clean the plug)
Once clean and working remove plug smother in silicone grease and shove back on
Barack Obamas 'beast' causing a few problems. HitomiLee Leisure Lounge 15 29-05-2011 16:49
(T) Injector light appears after 2 miles causing engine to stall. 127250 Barchetta 20 31-05-2010 20:46
alloy wheels causing me problems. help needed mcjacko1987 Bodyshop 5 31-07-2009 12:49
(S) rusted on JjPhoenix Punto (Mk2/2b) 15 25-04-2007 15:03
(G) Air Filter Keeps Causing Problems volxstu Punto (Mk2/2b) 4 26-02-2007 15:46
