rodduz
Member
Just been out in my 1.3 Mjet 75bhp. Going up a steep hill in 3rd and there was a loss in power for a split second, then it came back straight away, under 1/2 second. At the same time it beeped, like it does when got below 30 miles of diesel left, and flashed 'check engine' with the engine light illuminated. I pulled over, restarted it, warning was again given, drove it 15 miles with it running as normal, no loss of power etc. High revs, low revs, all seems ok?!
Any ideas? I immediately thought turbo as it was in that rev range that the power loss happened but I've had a listen and I can hear the turbo spooling (whistling quietly) as it does, normally.
NB Battery is on it's last legs I think, not sure if that makes a difference.
Any help much appreciated.
