Ok changing a bulb on the drivers side, what's the best way to get in at it, remove the airbox? Shredded part of my hand trying to get in at it.
Headlight bulb on a t-jet.have you seen this Vance?
https://www.fiatforum.com/grande-pu...ing-headlight-side-light-indicator-bulbs.html
Read the guide but still can't seem to get the wire to go back on after putting the new bulb in.
Tried taking the airbox cover off to get more hand space around the headlight, all to no avail though, going to have to get the ****er out
I've more than likely mangled the clip, luckily I still have the standard headlights in my loft, so could swap the clip and that's a long trek for a bulb haha. I've put the car into my local garage to take the headlight out while I'm away with work and hopefully when I get back it will be sorted.Working for Halfords I have fitted a fair few of these, the clips can be quite tight on these. Is the bulb in correctly and 100% flush, this would stop the clip closing fully. If this seems to be happening, try to close the clip with the bulb out.
The clip is a hook style design, if you can try forcing it back and slightly to your left it might catch the clip. Only other problem may be that you have snapped the hook catch on the holder, or possibly crushed it by applying way too much force.
Failing that, you know where I stay Vance, if you fancy a long return trip. Your local Halfords or garage should be able to sort this for you.
