can you please host pictures in the forum gallery and not offsite and make it smaller some of us use dial up
I just thought 'Dial Up', then realised you're currently in Moscow
Mozzarella: Thanks for the picture (huge file by the way),. Any chance of pointing out the mod because I cant see what Im looking at . Thanks
Following my phonecall, Fiat UK have sent out a reminder about this issue to their Network.
Are there honestly dealerships that dont know this!
ask their dealer to do so on the owners behalf, where Fiat could look at offering Goodwill in the circumstances. Personally i'd push for this in all instances as it is a design fault.
Are fiat paying the dealer for carry out the mod?
He didn't say, nor did i ask, but i'm guessing not if the car is out of warranty.
Im confused, which cars are affected by this?
The video by Alex shows what happens if you have the correct one fitted.
However if it's a Multijet diesel then it's less likely it'll have a problem, as the layout under the bonnet is slightly different & i think the alternator is placed out of harms way on the diesels.
both of those videos are of cars without aircon yes? as mine looks to have a huge aircon unit above the alternator would mine still be affected
Although it's fitted the wrong way round. It should drain to the N/S (behind the alternator) on petrol models, and to the O/S for Diesel models.
Service bulletin covers both petrol and Diesel. Alternators are mounted in similar positions (behind the block).
The car in the video above does have A/C.
In my experience, the majority of alternator seizures were on models with air-con, which incidently have an expensive alternator with unique design, of which weren't available from anywhere but Fiat.
Be my guest if you think you can fit it like that! That's the only way I could get it to fit, plus it doesn't drain on the alternator anymore so problem sorted!
