Thread Tools
Old 26-12-2007   #1
-Butwig-
tozzleozzle has donated!
Exclamation Head lights
1 of my chrimbo preze's were white headlight bulbs but i cant figur out how to take the top of the light apart to put the new bulbs in
any 1 no how????
Tom
http://petitions.pm.gov.uk/Lowerduty30
tozzleozzle is offline Reply With Quote Quote
Old 26-12-2007   #2
JFL
you penis!!
JFL's Avatar
JFL has donated!
Kazakhstan
Re: Head lights
In the Grande Punto you can just put your hand in the wheelarch and change them i think (much easier then my stilo which is a pain in the ass)
there might be a guide in the sections above somewhere
FAMILY WAGON..... WITHOUT THE FAMILY
BRAVO 150 MULTIJET DYNAMIC
FANCY A BUM?
JFL is offline Reply With Quote Quote
Old 26-12-2007   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Head lights
A nice easy one
Josh your thinking about the indicator replacement hatch in the arch
no need to take the lamp apart open the bonnet
Look through the lens and make a mental note of how the bulbs aligned (look at the bulbs in built reflector)
at the back of the lamp there is a rubber disc pull that off
now feel in the hole for the back of the lamp there is a black electrical plug pull that off the bulb.
now feel for the wire retainer you have to push it in and to the right or left then release and it drops down.
pull the bulb out
put your new bulb in (dont touch any of the glass with your fingers (if you have done already you MUST clean them with IPA or meths before you fit them or they will burn out prematurely)
slide the new bulb in and align it visually from the outside and give it a wiggle till its tags drop into the recesses on the inside
lift the sprung metal clip back up and push tight and move to the left/ right and release. it will lock in place if not try again.
next refit the plug on the back of the bulb
then put the rubber cap back on.....
and now test the lights.
Old 26-12-2007   #4
-Butwig-
Re: Head lights
SORTED MAN! thanks a billion
Old 30-12-2007   #5
Red all over the land
Kop32 has donated!
Re: Head lights
I to have got new bulbs for my GP 130 and either I have flippin big hands or you have very small hands because I can not get the bulb out ( i've still got the cuts to prove it), can I take the whole headlight unit out easily?.
Kop32 is offline Reply With Quote Quote
Old 30-12-2007   #6
Moderator
Andy Monty's Avatar
Re: Head lights
mines an active 1.2 so you could hide a small child in the engine bay a lot of it is knowing what to do once you have done a couple you can do them with next to no room there is always the option of removing the arch lining *( i wouldnt remove the headlamp unit as it would need re aligning after)*
Old 31-12-2007   #7
Kop32 has donated!
Smile Re: Head lights
Well I have finally fitted the new bulbs, they are a massive improvement to the ones that were in it, anyone interested I got them here.........
http://cgi.ebay.co.uk/Xenon-upgrade-...QQcmdZViewItem
Thread Tools
(T) Head lights high beam.. help Athos Stilo 11 25-03-2007 21:44
(T) Head Gasket Repair / replacement!!! derekmcluckie Punto (Mk2/2b) 8 02-08-2006 14:39
(G) Quad Head Lights Ryan m Stilo 11 12-02-2006 13:06
head lights ryan_welsh Lets Talk FIAT 7 23-01-2005 23:26
