Old 11-07-2007   #1
Flat Spot
Over the past few months, an annoying flat spot has developed on my GP 1.9 Sporting.
It tends to happen mainly when the engine is cold, whilst accelerating in 2nd or 3rd gear, and feels like a momentary loss of power (like I've suddenly let go of the accelerator and put it back again).
It's at low speeds (up to 30mph) and below 3,000rpm.
Dealer has looked at it twice and updated ECU, but has been unable to re-create.
Any suggestions please?
new2fiat is offline Reply With Quote Quote
Old 11-07-2007   #2
Re: Flat Spot
Same prob as me mate. ECU update does nothing for it either.
Fault with mine is a sudden loss of power and double jerk (pardon the pun) around 2 n half thousand revs in second gear while cold, in every 1 in maybe 10 cold starts
captain chaos is offline Reply With Quote Quote
Old 11-07-2007   #3
scottyJTD has donated!
Re: Flat Spot
I had the same thing, after i changed the MAF,not as violent though just a slight hesitation at 2600RPM in third.
I had a MAF problem changed the MAF and it went away for a couple of days,i then put and enclosed IDNK in as i had to break up the original air box to change the filtter,so could get an IDNK easeir than the OG air box.
Any way it came back but worse,the new MAF i got was a cheapie of fleebay and was advised get rid and get a bosch so did,and it went away,but still sometimes gives a little hesitation when warm not when cold.???
It is a puzzler.
Scotty
scottyJTD is offline Reply With Quote Quote
Old 12-07-2007   #4
Re: Flat Spot
Glad I'm not the only one with this! Yep, the problems you're both describing is exactly the same as me.
Guess my only option is to take it back in to the dealer and try to demonstrate....I'll just have to leave it there all day and demo it after work when the engine is cold. Trouble is, it doesn't do it on every trip, so it'll be s*ds law that it won't do it!
Old 04-06-2008   #5
Re: Flat Spot
Has anyone who had a flat spot in the GP managed to fix it/find the problem?
Mine's still there, but better if I only fill with Shell - any other diesel and it's much worse.
Old 04-06-2008   #6
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Flat Spot
I only use Shell and so far have not seen or felt this in 30k miles.
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 04-06-2008   #7
Re: Flat Spot
Weird...obviously something unusual!
Old 04-06-2008   #8
Red all over the land
Kop32 has donated!
Re: Flat Spot
I to have a 1.9 mjet sporting and the very same happens with mine, it went in for it's first service last week and even though i mentioned it to them they found nothing wrong, glad (if that;s the right word) to hear i'm not the only one, please advise if anyone gets a fix to this.
Kop32 is offline Reply With Quote Quote
Old 06-06-2008   #9
Australia
Re: Flat Spot
Yeah mine has the same problem. Been to the dealer 3 times, updates done, but the problem persists . Mine is a June '06 build 1.9 Sporting. Would be interested to see if this defect is present in later model vehicles or if the fault has been identified and fixed by Fiat. What are the build dates of your vehicles???
Dirty Waltzer is offline Reply With Quote Quote
Old 06-06-2008   #10
Re: Flat Spot
Yep, mine is a June '06 build too...coincidence??!
Old 06-06-2008   #11
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Flat Spot
Quote Originally Posted by new2fiat View Post
Mines a 56 plate, not sure of the build date.... where is that guys? Maybe its a pre 56 thing... in which case FIAT should know what the cause is..
Old 06-06-2008   #12
scotzman has donated!
Re: Flat Spot
mmm mines a an 06 plate as well anyone tried an aftermarket remap see if this cures it?
scotzman is offline Reply With Quote Quote
Old 06-06-2008   #13
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Flat Spot
Quote Originally Posted by scotzman View Post
Now that is a good suggestion.
Old 08-06-2008   #14
Jap Slut
puntokris's Avatar
puntokris has donated!
Re: Flat Spot
Mine has done this once and that was just after my remap and induction kit, I put it down the the dual mass flywheel struggling, and it hasn't done it since I unplugged the MAF...
C:\Users\User\Pictures\Type-r
puntokris is offline Reply With Quote Quote
Old 08-06-2008   #15
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Flat Spot
I'd be closely looking at the operation of the EGR valve.
(T) flat spot when hot Bushboy Cinquecento / Seicento 17 13-03-2010 15:50
(T) Flat spot in 1st: ECU question... ronnieronson Cinquecento / Seicento 23 02-06-2007 09:20
(T) BIG flat spot! chazzer Cinquecento / Seicento 53 25-04-2007 22:02
(T) Strange Flat Spot? EvilJaxx Cinquecento / Seicento 17 06-05-2005 12:44
(G) Carb flat spot Uno 60S (Solex carb) Brymak Uno 3 29-11-2004 02:06
