Technical New noise
Technical New noise
luvduvs
SNAP!
Sydney
Just noticed this - when I accelerate slowly to a crawl, then stay at that speed, I hear this noise which I can only describe as a soft metallic scrapping (like rubbing two pieces of metal back and forth), and goes away as I pick up speed.
Anyone else have this, and is it normal?
Can you hear the other noise, the slight whirring as speed picks up?
I reckon the above suggestion is likely, brakes are the cause, a certain chassis range is subject to a technical bulliten where a mod is performed on it may be worth seeing if yours is affected by this
i severly doubt its the pistons.
checked your oil?
Yep oil is fine.
But I'm not using the brakes..
please not another 17 page saga :cry:
Nevermind - its ok when others ask a stupid question but its not ok when I do.
Yep oil is fine.
pads touch the discs lighty which creates the noise. most cars do it. mine does. my dads does, and so does my mums (y)
Thanks for the reassurances, now I can sleep well again :D
Kev the topic has nothing to do with it............its just this dread I get when you start a post I know its going to end up a epic!!!
Light-hearted friendly 'banter' thats all.
Remember these 'epics'.......
https://www.fiatforum.com/grande-punto-technical/82628-first-second-gear-pt1.html
https://www.fiatforum.com/grande-punto/103776-kangaroo-grande-punto-platypus-pt2.html
:D
Yes, Drama-Queen-Kev strikes again.
when i drive at speed and open window it sounds like a windy day even if there no wind, do i need a new window or a new door?
Sounds serious.. I think you'll need both a new window and a new door :chin:
