FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->fitted Aux input<!-- google_ad_section_end -->
fitted Aux input
Published by lukedmartin88
10-06-2011
Unrated
User Rated:Unrated
Ok so I've been asked to make a guide, bear with me as Iím usually useless at explaining things!
I donít have blue & me in my car and was getting fed up with having a wire hanging about for the AUX input, so I pinched an idea from my wifeís Corsa.
I bought 2 adapters on eBay one to go from the HU which split into red and white cables. (You may need to adjust the order the cables are in at the end of the adaptor)
http://cgi.ebay.co.uk/Blaupunkt-Aux-...item3ca674e665
And then one which plugged into these with an input on the end.
http://cgi.ebay.co.uk/3-5mm-Female-A...ht_2473wt_1139
Thanks Cadabena, DlightSwitch thanked for this post
Likes Andy Monty, DlightSwitch, Grainge16 liked this post
Contents
<< <    Next Page: Installing Input (Page 1 of 3)    >  >>
Old 30-03-2013   #1
Cadabena has donated!
Re: fitted Aux input
Thanks for the useful guide! Just done this myself, although I made the electronics a little easier and just got the Blaupunkt - 3.5mm lead from eBay to go straight into the metal female - female that I epoxy-resin'ed to the centre console. Quite pleased with the results if I may say so!
ID:	114820   Click image for larger version
Cadabena is offline Reply With Quote Quote
Old 14-04-2013   #2
willmott1992 has donated!
Just came on to write a guide on this, then realized you'd done one I did mine exactly the same, including the rca connection in the passenger foot well. However due to using the screw type of 3.5mm socket, I had to spend a good 20 minutes sanding the center console to be thin enough
ID:	115579   Click image for larger version
willmott1992 is offline Reply With Quote Quote
Old 20-05-2013   #3
Fiat Freak
Theta2's Avatar
Theta2 has donated!
Not sure if I'm just being thick but why do I need to be able to disconnect it?
Can it not be left in permanently?
Thanks, Alex
Likes contractor liked this post
Theta2 is offline Reply With Quote Quote
Old 23-05-2013   #4
A few reasons:
1. Kept getting caught when closing the glovebox (sooner or later would have broken the cable)
2. If the end breaks you only need to replace the 3.5mm male-male, not the whole expensive Blaupunkt connection
3. Use any length/angled end 3.5mm cable you want
4. Looks so much more professional! Will probably add £100 on resale just for saying it has an aux input
Old 15-02-2014   #5
Thanks for this! Simple but worthwhile
CarlFisherrr is offline Reply With Quote Quote
Old 06-06-2014   #6
hi
I have a 2006 gp sporting with the usb media centre in the glovebox. Does this mean that this media centre will be using the space for the aux lead to go in or is the media centre plugged in in a different slot
cheers
MarkJWebster is offline Reply With Quote Quote
Old 22-06-2014   #7
Greece
This is genius! May try it in my Punto Mk2...
hisXLNC is offline Reply With Quote Quote
Old 10-11-2014   #8
Croatia
Quote Originally Posted by MarkJWebster View Post
hi
cheers
could someone answer this
xtr3m3 is offline Reply With Quote Quote
Old 12-04-2015   #9
Thanks for posting the guide. I've just done this on my daughter's car. I went for the fitted socket - in the same place as Cadabna and Willmott1992. There were a couple of small variations though>
1. I used this lead for the back of the radio for £6.50:
http://www.ebay.co.uk/itm/3606973607...%3AMEBIDX%3AIT
2. I used this lead for the centre console because it's a screw-locking female 3.5mm receptacle:
http://www.ebay.co.uk/itm/3015748225...%3AMEBIDX%3AIT
3. I used one of these to connect the two together:
http://www.ebay.co.uk/itm/4004193750...%3AMEBIDX%3AIT
I didn't take the centre console out, I pulled the gear lever gaiter off and already had the radio out to fit the lead to the back of it. I was able to drill the centre console with a 6mm drill in-situ, drop the lead down from the radio slot, reach up the gear lever hole to grab it and push the socket up from underneath.
Avocet is offline Reply With Quote Quote
Old 26-06-2017   #10
Sorry for bringing up an old post.
Help! I bought an AUX in cable that you plug into the back of the radio unit. And plugged it into the back but nothing is happening. What am I doing wrong???
Loppetz is offline Reply With Quote Quote
Old 26-06-2017   #11
Fixing It Again Tomorrow
lukedmartin88 has donated!
Did you check the connection positions?
https://www.fiatforum.com/grande-punt...active-hu.html
lukedmartin88 is offline Reply With Quote Quote
Old 26-06-2017   #12
Old 26-06-2017   #13
Also did you press the CD button twice? Does it say AUX on the screen... if not if i remember correctly you may have to activate it. I cant remember off the top of my head as the Punto got replaced with an Astra 5 years ago 😁
Old 07-11-2017   #14
Mega Aphormḗ
NWintherkl's Avatar
NWintherkl has donated!
Denmark
If you have the Delphi version you need to connect it to the AF R and AF ground AF L, plus D Out and D In must be bridged...will not work if you have Blue and Me.
Information is not knowledge.
NWintherkl is offline Reply With Quote Quote
Comment
Search this Guide:
(T) aux input rossi g Grande Punto 13 11-10-2010 16:07
(T) Aux Input adzAbarth89 Stilo 2 08-09-2010 20:12
(G) AUX Input arteta6 Grande Punto 5 26-12-2008 01:06
aux input euan hay I.C.E 1 30-08-2007 16:15
(G) AUX input forevertom Panda 3 06-03-2007 07:20
