Installing Input
I began by removing the part by the gear stick and handbrake (not sure what it’s called!)
First of all remove the bit surrounding the handbrake (give it a squeeze and it should just pop out)
Then remove the leather bit around the gear stick (again it just pops out) if you look in the area where the gear stick is you should see a wire for the cigarette lighter, this just pops out at the bottom.
Remove all the nuts securing the tray bit in place (there is a couple in the foot wells!)
Remove the tray, flip it over and drill through! (I used a 7mm drill bit but check with the size of your input) dab some super glue around the base of the tray where your hole is and pop the input lead into place.
Now put the tray back into place. Don’t forget to leave the red/white leads hanging in the passenger foot well, this'll allow you to easily connect and disconnect.
