FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Breather hose replacement 1.2 & 1.4 8v<!-- google_ad_section_end -->
Published by Andy Monty
08-02-2011
Difficulty Level: 2
User Rated:
Difficulty Level: 1
Oil / Fume smell drawn in by your heater / blower which goes away if you stick it on recirculate it could be your breather hose has split...
tools needed
10mm spanner / socket, ratchet and short extension
end cutters or CLIC AND CLIC-R type pliers
and nut runner / screw driver for jublie clips
new breather hose part #71769083 (modified/ improved part)
jublie clips to suit circa 20mm
first open the bonnet and free the air box
to do this
remove the rubber front intake mount by pulling it away
like so:
next with a 10mm socket / spanner remove the 2 mounting bolts:
and take care not to loose the 2 "top hat" spacers from the mountings:
next support the air box and pull up slightly to remove from back mounting:
and pull off smaller breather hose off back of air box (this is just a push fit)
its worth looking at this one too for signs of cracking too
for reference it locates on the bottom of the inlet manifold
These are the type of clips your are now confronted with on the breather hose (i removed mine a while ago so a pic of one on the Radiator bottle will have to suffice to show you what you are up against.....
i just nipped mine with the end cutters till they released
like this
but you can use the correct pliers if you want to re use them (i just used Jublie clips (worm drive hose clamps when i refitted makes it simpler to clean out at a later date and to change the air filter just undo one and whip the lot off)
then pull the hose off each end and replace in reverse order (i found it easier to fit to the air box first then to the rocker box top) when tightening jublie clips dont over tighten on the plastic spigot on the air box as you can break it just nip it up enough to stop the hose from pulling off
DO NOT FORGET to put the small breather back on the air box when re fitting
Old 15-02-2011   #1
Matt Boulton has donated!
Re: Breather hose replacement 1.2 & 1.4 8v
when fitting a GSR kit
where does the vacuum hose go???
as there is nowhere to plug it on
Matt Boulton is offline Reply With Quote Quote
Old 15-03-2011   #2
strutty has donated!
Just to say.I have just changed the oil breather pipe (I was praying there was a hole in it) the hole was 3 inches long and the pipe had completely collapsed.It took me about 20 mins.So a big thanks to everyone especially.
Andy Monty.
strutty is offline Reply With Quote Quote
Old 19-03-2011   #3
bluepunto2 has donated!
Where does the small breather Pipe go to ? I have it connected to the air box but it's just hanging down back of engine? Not Plugged onto anything!
2007 "56" Grande Punto Dynamic 1.2
4653
bluepunto2 is offline Reply With Quote Quote
Old 20-03-2011   #4
Moderator
Andy Monty's Avatar
Andy Monty has donated!
it goes on the inlet manifold
if i get chance later i will post a picture up
Massive gash
Just a little touch up
Old 20-03-2011   #5
Quote Originally Posted by Andy Monty View Post
Please do cause I can't see where it should go...
4653
Old 13-04-2011   #6
Thanks very much for these instructions-saved me loads of time messing about booking punty in the garage and if course money. I did it in half an hour and I'm a girl! Thanks again
Suz88 is offline Reply With Quote Quote
Old 14-04-2011   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
most garages do it for free, takes few minutes.
Old 19-05-2011   #8
Hi all,
This is my first post on this forum...
My girlfriend has a Grande Punto 1.2 on a 57 plate. I recently did a bit of a mini service (plugs/filter etc) and noticed the breather pipes were split.
I have replaced the larger breather pipe with no problems at all but need to replace the smaller pipe at the back (have taped it up for the short term).
I know it just simply pulls off the air box but cant see how detatches at the other end?? (from the bottom of the "inlet manifold") Does it just pull off too or is there some kind of clip that I cant feel?
Also, would a silicon vacuum pipe with a 5mm hole be ok to use for this?
Thanks in advance,
J
T25 is offline Reply With Quote Quote
Old 21-05-2011   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
just pulls off
Old 27-05-2011   #10
Quote Originally Posted by T14086 View Post
just pulls off
Thanks T14086, I tried to pull it off but it didn't seem to want to budge?!
I thought I heard somewhere about letting it warm up a bit first, so after a run out in it I tried pulling it off then.... It popped off with no problems!
I guess the heat helped somehow?!
The silicone pipe works a treat too. I paid about 4 off Ebay (delivered), it just slid straight on with no probs and now runs really nice.
Old 11-06-2011   #11
Trader Rating: 2
colin79666 has donated!
Cheers for the guide. Easy job to do when you know how
colin79666 is offline Reply With Quote Quote
Old 27-07-2011   #12
Romania
Hello,
I change my stock air filter with a K&N 57i Series Induction Kits (57-0655), and the installation guide tells me that I must block the air breather hose (not oil breather hose, it is a very narrow rubber hose, under air filter). It is ok or wrong to do that? What is the meaning of air breather hose?
Andrii is offline Reply With Quote Quote
Old 06-08-2011   #13
Ireland
great guide andy. just one question. I did this today on my 1.4 8v GP, but couldn't find where to put the flame trap. after a bit of reading, it seems i should've inserted it into the breather pipe? is this correct, and if so, which end does it goes in to?
deadduck is offline Reply With Quote Quote
Old 24-12-2011   #14
Angry Re: Breather hose replacement 1.2 & 1.4 8v
Great guide and advice guys ,,I had this problem when my GP was 8 mths old ,under warranty so took it to my local dealer. First visit got the usual excuse that they would have order the parts.Two weeks later finally got it booked in to do the work (didn't ask the cause ,the petrol smell stopped and I'm no mechanic so was happy) now 18 mths on, petrol smell back and have just looked behind the air filter to find a cracked breather pipe with 6 inches(and I'm being generous with that) of red insulating tape wrapped round it...
So thanks again for the guide I'll do it myself this time
jink is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Breather Pipe/ Hose dansmitts Grande Punto 5 09-02-2011 10:10
(G) Breather hose replacement Luca91 Punto (Mk2/2b) 4 06-02-2011 20:15
(T) Breather Hose RobSport Grande Punto 6 12-10-2009 21:24
(G) K&N 57i breather hose Aliweasel Cinquecento / Seicento 15 18-11-2007 00:58
(T) 899CC Breather Hose badboyz016 Cinquecento / Seicento 11 28-07-2004 19:44
