W
Wimmy
Guest
Grrrrr.
On the way home from work this eve my clutch decided it wasnt going to grip properly accross all the gears.
The new clutch has only been in a month and the 2nd hand gearbox has been in for 20k.
I also got a clunking/knocking noise from the left wheel when turning right.
GeForce reckons my gearbox is gone. The seal on the end comes with gearbox only and will be a full replacement.
I've noticed a little oil under the bottom of the box where it meets the block. Can anyone advise if its a new box or can I get a seal and also if the knocking is related?
Thanks in advance
Your eternal leader
Wimmy
(need it sorting asap for Stanford!!)
Thanks in advance
Your eternal leader
Wimmy
