Im putting my power through today for my amp, I did it with out much trouble on my hlx but it seems to be a different story on my hgt, where can i run it through, grommets seem 2 be 2 low down!
Its not ideal, but what i did before i found this forum was to run it accross the engine bay and through the foam between the engine bay and the front wing, you can see when you open the door, and then around the door seal then through the kickplate at the bottom of the door. Only prob is you can see where it leaves door seal and goes into the kickplate.
if you put your hand up into the passenger footwell you will see a rubber seal with some wires going through, from the engine bay side push a piece of coathanger wire through then tape your power lead to it and pull it through from the inside
