Comment
Guide Tools
<!-- google_ad_section_start -->fitting new front brake discs<!-- google_ad_section_end -->
Published by dave
09-11-2011
Difficulty Level: 2
User Rated:Unrated
jack up car and support on axle stands, remove wheels
spray brake cleaner on brakes.
remove wear wire and remove flexi hose from shock.
remove bottom bolt holding calliper to its carrier and remove pads and the little bits of metal on the carrier.
ID:	96067Click image for larger version
remove cap on brake fluid tank, and push back piston with a clamp, DO NOT USE A BAR,
ID:	96068Click image for larger version
remove top calliper bolt and tie carrier up out the way to prevent the flexi getting stretched.
spray more cleaner on calliper
remove calliper carrier bolts and then remove carrier.
ID:	96071Click image for larger version
when its off give it a good clean.
remove bolt that attaches disc, then remove disc, you can tap it off with a hammer if you are fitting new ones.
clean up the hub, some people smear with copper grease after if you do make sure its an even thin layer or disc wont sit true.
fit new disc carrier and the metal things.
[ATTACH]Click image for larger version
Put copper grease on all bits of pads that contact the calliper and carrier
forgot to take photos of that bit, fit rear pad to calliper piston and front pad to carrier.
use new calliper bolts or clean the treads of the old ones and apply thread lock.
then refit calliper to carrier
reconnect wear wire and refit flexi to shock.
re fit wheels. when car is back on the ground torque wheel bolts
This is a guide only its just to help if you are competent, if in any doubt seek professional help
Likes Vento, ben liked this post
Old 15-11-2011   #1
Trader Rating: 10
dave has donated!
Re: fitting new front brake discs
forgot, you should also remove the 2 slider pins, clean and regrease them too.
Comment
Guide Tools
(T) Fitting new front discs and pads donnymad Doblo 3 21-09-2011 15:47
(T) buying and fitting brake discs and pads mikestrand Punto (Mk2/2b) 6 22-09-2008 10:22
(T) Fitting new brake discs and pads nicholasb Barchetta 26 09-06-2008 23:46
(T) tips for fitting new brake discs. 4paws Uno 8 09-05-2006 21:18
(T) Fitting brake discs!! Southey Cinquecento / Seicento 6 17-11-2004 16:03
