Hi guys,
Outside at 6am checking car over, numberplate light didnt work, :bang: connection problem behind bumper so knew it would fail! Left lights on when checking, went to set off, battery dead! lol so jumped it, got it there.. phonecall from tester, your alarm keeps going off when i open the door.. *i think: didnt even set the alarm* he says the fob isnt even working!.. pop down at lunch, rip out the alarm connections so it no longer goes off..
Then get another phone call..
It failed on:
PS Headlight Alignment (easy)
DS Headlight Alignment (easy)
PS Windscreen Wiper (easy)
DS Windscreen Wiper (easy)
DS Rear Number plate light (easy)
CO Emissions excessive eek
So he said that the problem could be Lambda "has it been using lots of petrol?" Yes, which then apparently causes the Cat problems..
Luckily i have a spare of both in the shed, so will fit them, dad also says put 30mm TB back on as opposed to 38mm currently fitted.
What else could i do to reduce emmissions/what else could be causing it??
Craig
It failed on:
Craig
