- Feb 11, 2006
- 6,866
- 1,040
Right, these are the problems I have identified so far for MOT time;
So are all of these potential MOT fails, I know the wheel bearing is, also sidelights and brake lines, but any of the others?
- Offside Rear Bearing slightly loose
- Very very slight play in offside track rod end
- Rear Brake cylinders not working as freely as they should
- Rear most brake lines showing some signs of corrosion
- Rubber covers on suspension split (behind the coils)
- No sidelights
- Steering wheel off center but car not pulling to any side
