Hello guys,
I have almost finished with my project which was to make my 1.1 as tuned as posible for road use mainly.
-Reprofiled Punto 75 cam to 280 deg and 10,45mm lift
-Ported and polished mpi head
-Higher compression
-Full custom 4-2-1 decat exhaust
-Punto 75 inlet manifold
-40mm Punto 75 throttle body
The problem here is that when i changed the inlet manifold and kept the coolant temp sensor out of Punto 75 and did a little cut and connect wiring thing with the OEM mpi wiring to fit the P75 sensor but my OBD scanner reads very low values (under 76 degrees celsious) even when i am stuck in traffic. I understood that something goes wrong when i squeezed the thermostat hose and it was hot, so the engine was running over 87degrees. So the engine overheats but the ECU doesn't read that so it doesn't give order to ventilator to open and reduse the temperature.
Any idea on what i have to do now to solve my problem?
The car now can't be moved with no risk of blowing everything up...
-Higher compression
