Check the timing belt pitch before buying a pulley, theres two different types.
I"d go for the 40mm TB from sparky l, cheapest option when compared to a pulley or piggy back ECU
P.s it should rev to more than 6500!!
Cheers for the help Brooky, where are you Lancaster ? if i drove the car up to see you would you be able have a good look at it and point me the right direction with tuning and have a drive of it, It would be good to have it running spot on.. Sparky is going to do the throttle Body for me ... but is it possible to go to 42mm ? 40mm is what you guys are saying and is cool, was chatting to the guy that built it and he questioned if 42mm would be a better call ?? cheers Ade
