how hard is it to do? just had the offer of a cinq that needs these, they are provided.. wondered how long it takes??
Please help asap as i have first approval of the car...
Ive done all the preliminary loosening and removal of everything except the bellhousing bolts, enmgine mounts and the hub nuts in under 2 hours....
But yes, the gearbox is heavy (33kg in a 600 x 300x 300 package)...so a support or a person to help heft it out is definately recommended...dropping it on your face isn't preferable.
Clutch change takes 5-10mins with the G/B off...just use a clutch alignment tool as it prevents lots of problems if the shaft wont go into the clutch plate!
