Hey Fiat Fans
After heavy rain(over 10 days) an local flooding my Fiat has started to act strangely. On start up the dash will show the high beam light(I don't usally switch off the lights when shutting down) even though they are 'dipped'. A quick flick 'resets' them back to normal. Also the fuel guage sometimes flicks up and down during the starting cycle(not in a normal fashion but it flickers/if that makes sense?) On top of that the clock has stopped displaying the correct time and appears to show the time since first start up, initially showing 00.00 hours. Speedo works okay and odometer is good.
I started the car up a couple if days ago and it struggled to get going, turning over on the starter only. Very rare for my Seciento(after a ten minute drive) and then when it did revved up and down by itself for maybe 10-15 seconds before settling back to 'normal' idle. It was as if I was revving the car myself.
Now, what with the rain I have had to 'wade' through some fairly large puddles and now I think the alternator may be suffering. I replaced itvlast year after the bearing seized and think that the water etc has maybe washed out some bearing grease? Anyone got any tips for re lubricating the bearings 'in situ', and what would be best to use?
The battery is the one it came with from my mate but isn't the original. The car is always garaged and well looked after....just think it may have caught a cold.
Haven't noticed any warning lights....haven't got a OBDII reader YET!!
Any advice would be great
Many thanks
Malcolm
Marbella
Many thanks
Malcolm
Marbella
