Thanks for your suggestions. I was thinking that with such low miles the possibility of brushes etc being worn would be low.
From some searching on these forums I see mention of rectifiers & diodes etc causing problems at times. I think I'm probably heading towards removing the alternator & if not easily sorted, sourcing another. I had actually replaced the drive belt while doing the timing belt several weeks back.
Was hoping that with 14.6 v showing that I might be able continue using the car with a slightly glowing charge light for the time being at any rate !
Not sure about your specific alternator, some are serviceable with a brush set , some come with a rectifier/diode pack and brush assembly as a unit.
Years ago I bought a Citroen Dyane with a faulty alternator and the brushes from the dealer were only £6 and cured the problem. Some later units have the wires inside electrically welded rather than a screw or push on terminal just to prevent DIY, although they would claim it made it more reliable
Generally 13.8 to 14.2 is a good charging voltage , so not far out.
Not suggesting getting violent, but if someone is watching the glowing light as a gentle tap on the alternator is delivered it may show if brushes sticking likely. As you say at 15k not going to be worn , but could easily be sticking so no parts required.
