Well after much head scratching in the conversion here are the 1st pics of the not yet complete but ruinning as it should Imola Hi-boost turbo.
Note the changes made in doing the conversion from my (sadly dead) red Van Aaken prepared Cinq the engine came from, namely compete re-route of hose to expansion tank from the 4 way connector at the bottom of the rad as it passes very close to the turbo, and the the not very clear in the pics, heat shiedling around the TB inlet pipe as it passes the exhaust manifold.
You will proably also notice the routing of the BMC Carbon Dynamic Airbox which takes the cold air supply from behind the fire wall/bulk head which in turn gets feed from the vent at the bottom of the windscreen which is an area of high pressure cold air.
Comments welcome as its a rolling project with many things left to do.
Front view of car, the Abarth bumper has still to be re-meshed with stainless steel mesh and the orange gasket thing painted black and joined by one on the othe side which is used to feed the oil cooler, which although unseen in the photo sits in that corner.
