Old 28-09-2005   #1
Question Inlet Air Temperature (IAT) sensor
does any one know where the Inlet Air Temperature (IAT) sensor is located and the engine coolant temp sensor?
rgds dan
dacater is offline Reply With Quote Quote
Old 28-09-2005   #2
Re: Inlet Air Temperature (IAT) sensor
engine coolant sender is at the rear of the engine near the cam belt cover. inlet temp sender is in the throttle body i think. I'll just check that and get back to you
primeruss is offline Reply With Quote Quote
Old 28-09-2005   #3
yes the inlet temp sensor is in the throttle body.
Why you asking anyway?
Old 28-09-2005   #4
Cool Re: Inlet Air Temperature (IAT) sensor
Old 28-09-2005   #5
Old 28-09-2005   #6
oh I see, There have been some threads about these mods before. The general thoughts are they are not much cop. it fools the ecu into thinking the engine is cooler than it really is and so enrichens the mixture. Fuel consumption increases and it won't pass the mot whilst fitted. Other than that I don't think they do any lasting damage. Start a new thread more relevant to what you want to do and get reaction on it.
Old 28-09-2005   #7
just considering it to be honest not sure if its worth the hassle if it might make my engine overheat from what your saying
Old 28-09-2005   #8
arc
this is where i stand
arc has donated!
dont do it..
btw the coolant temp sensor is in the inlet manifold, not the clyinder head. the one in the head is for the gauage
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 28-09-2005   #9
What about the IAT Sensor or is there not one in the sie sporting?
why not mod it? have you had a bad experience? or did you mean not on that sensor?
Old 28-09-2005   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
The engine managemnt system is not fooled for long. The Lambda senses the increased fuel and adjusts it downwards.
On a seperate note, overfuelling causes bore wash, lack of fuel causes overheating.
D
Old 28-09-2005   #11
Might pass on the idea the part only cost me 4. is their an IAT sensor in the sie sporting?
Old 28-09-2005   #12
yes you are right about the sender in the head but when I answered the question it was not clear what was being asked.
Old 28-09-2005   #13
Sorry about my question if it was not clear! tell me how i could have made it clearer for next time
tnx dan?
Old 28-09-2005   #14
Nothing wrong with the question at all mate.
My brain was not working on the same wavelength, if you had said
I'm thinking about one of these resistor thingies then I would have known that it was the fueklling sensors you where looking for not the temp guage one. I should perhaps of twiggede by the second part of the Question about the Inlet temp sensor.
But hey sometimes I'm not perfect.
Old 28-09-2005   #15
all good fella thanks for your help anyway. actually while i am asking do you know if there is a temp gage you can get for the sporting that can be fitted so i can see how hot the car is getting?
(G) Air Box Modification polecat Marea 105 09-07-2011 18:28
(T) 1.1 SPI Air Sensor geom Uno 8 24-06-2005 10:44
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
(T) air box mod revisited jbackg Marea 1 18-08-2004 02:33
(T) IAT Sensor, help please marlie1298 Bravo / Brava 1 09-10-2003 01:39
