amiller112
Hi, I have recently fitted a new thermostat to my 95 SX cinquecento. However I may have damaged the temp sensor as it doesn't show any reading on the dash guage. Is there a way to test if it is working?
In the haynes manual it says that the coolant resistance is 10K ohm at 0C and 5K ohm at 20C and so on, is this the resistance that the sensor reports?? If so I do have the equipment to test for this.
Also anywhere I can get a replacement apart from fiat as it will cost £33 for a new one. Also does anyone know what tool you can use to remove the sensor while the thermostat housing is still attatched to the engine?
Any advice is welcome as I have now hit a :bang:.
If it is working I can seal it but I need to know how to remove it safely.
If I drain the coolant would I be able to reuse the gasket? I just fitted a new one today.
