Old 01-09-2005   #1
Clubcento Member
CaneyJ has donated!
Will an alloy of et49 fit a cinq?
The whole thing about alloy fitments is still confusing to me. I'm looking at an alloy with a PCD of 100 which I heard is ok to fit with wobbly bolts. I know cinq et is around 30 but the alloy i'm looking at is 49. Other details are that they are 14*5.5 and come with 195/60 profile tyres.
Would this fit simply but adding 19mm spacers and are there any other issues?
I also know a sporting already comes with spacers. How big are they and what is the et without them?
CaneyJ is offline Reply With Quote Quote
Old 01-09-2005   #2
J333EVO has donated!
Re: Will an alloy of et49 fit a cinq?
Quote Originally Posted by CaneyJ
The sproting comes as standard with 3mm spacers up front.
Yes 19mm spacers will giv ethe correct off-set of 30mm but you will not get any that size 20mm will b ethe closest and they will be costly.
Eibach available here http://wwww.motorsportworld.co.uk/
FK available here http://www.performancedriven.co.uk/s...ID=104&CatID=3 or steel ones from here
http://www.wheel-spacers.co.uk/
These are all proper hub centric spacers which means you have much less chance of wheel wooble and they are much easier to fit than the universal ones which I would. dream of using at all.
When I bought my Imola it had 6mm universal ones on it and the wheel wooble was horrible at speeds above 50mph, but with my proper hub centris ones it is no more.
Further more the GT wheels are off-set 45.5mm 14" 5 1/2" wide with 175/50 14 rubber and I run 30mm FK spacers making an off-set of 15.5mm and I have a much much more stable car and very limited rubbing on extreme cornering and thats with standard springs and Eibach lowered springs.
HTH
Aaron.
Cinquecento Abarth 1.4 16V 6speed track toy
Lancia integrale EVO1 Homologation model
MINI Clubman Hampton Edition Cooper SD
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
Old 01-09-2005   #3
HP
I was only doing 80...
HP's Avatar
HP has donated!
195/60-14's are too big a diameter, but you should ideally be looking at 185/50 as a max on a 5 1/2" rim.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 02-09-2005   #4
Trader Rating: 1
mase has donated!
Gary Golf Champion, SikTrix BMX Champion
Quote Originally Posted by J333EVO
now that is a gem of info..... have the spacers got rid of the wobble completely?
i neva really noticed untill a few weeks ago as it seemed to get worse, thought the wheels needed balancing
might have to pick up some hubcentric ones for the abarth then
R97 cinq 1242 <Ex Team Anthracite >
(now sold)
mase is offline Reply With Quote Quote
Old 02-09-2005   #5
Trader Rating: 1
you can get huge spacers to compensate for the offset, but the problem i had on mine was that the bigger you got, the spacers wouldn't sit hub centric. the place i got my wheels fitted advised against this, as any stress in the wheel would be transferred into the bolts which could mean they shear off at some point. you'd also need much longer bolts too.
sei gone :(
Alroy is offline Reply With Quote Quote
Old 02-09-2005   #6
Trader Rating: 1
mase has donated!
Quote Originally Posted by Alroy
actually...... when u look at gettin at least 15mm spacers each hub then FK do a spacer which is hubcentric and bolts onto the hub its self, then u use the standard wheel bolts to bolt the wheel to the spacer! which elements any of that stress.
(now sold)
Old 02-09-2005   #7
Quote Originally Posted by mase
Exactly, the spacers bolt to the hubs then the wheels bolt to the spacers therefore there is no added stress.
I know someone who runs 25mm spacers on a race car as that is the biggest your alowed and has never had a failure and his car runs slicks etc etc so think how much stress that car is under compared to a road car!
And yes Mase there is no wheel wobble at all now with the proper spacers, and I knew I woudl win you over to my way of thinking in the end when it comes to spacers You pays your money, you takes your chances!
Aaron.
VW MK5 Golf R32
Old 02-09-2005   #8
Trader Rating: 1
mase has donated!
Aaron.
lol i have to say i am impressed, there is very very little wobble on the abarth so i will hold out as i am savin for holidays in a couple of weeks, but if they make that much of a difference then i will get some 5mm ones in nov or sumtime soon!
(now sold)
Old 03-09-2005   #9
Trader Rating: 1
that's quality, might sort out the few niggles i have with my wheels!!
will invest when i come back from holiday
sei gone :(
