got the 1242 in and its running good BUT its got flat spots and holds back when your flooring it and tbh i dont think its performing how it should. Now I know for a fact that my inlet manifold is reused and onld. infact it was leaking coolant when i first put it on but i sorted it with some instant gasket.
now, i used all the same sensors and so on from the 1108 engine and i was having similar symptoms with that except i know the head gasket was going so put it down to that. at the time laods of people said it was the lambda ... but i changed that 3 times and it didnt cure the problem so i presume my lambda is fine.
Im pretty sure everything else is ok. i change the map today which didnt help.
but as i say.. i know for a fact that the inlet manifold gasket is dodgy and could be leaking air i suppose.
so would a dodgy inlet manifold gasket cause flat spots and kinda rough idling.
any other ideas?
any other ideas?
