Old 25-11-2011   #1
Cinq Sporting oil leak thru rocker cover?
Hi all
Have lately been noticing what appears to be a persistent oil leak through the rocker cover ('97 Cinq Sporting). The rocker cover gasket was replaced and oil changed at the same time as the head gasket was replaced in June of this year. Can the rocker gasket have gone already? How long are these things good for? For months after the head gasket job there was hardly any oil coming out - now it's definitely worse. Any ideas?
wolvescinq is offline Reply With Quote Quote
Old 25-11-2011   #2
Trader Rating: 5
fingers99 has donated!
Re: Cinq Sporting oil leak thru rocker cover?
Check that the breather isn't clogged. They don't last for too long, and there are a few tricks to making them oil tight.
First is absolute cleanliness (clean up all the surfaces as well as you can with acetone or spirit wipe (aka panel wipe).
Second, use a gasket sealant. I use silicone, but others say it's not a good idea for these. FIAT usually use a black one, but I'm unsure of its composition.
I like to just clench the bolts up, allow the goo to go off, then tighten down to torque. Whatever you do, don't overtighten.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 25-11-2011   #3
andys cinq has donated!
andys cinq is offline Reply With Quote Quote
Old 25-11-2011   #4
Thanks for that! Where might I find the breather though? And when you say they don't last long do you mean the rocker gasket? The garage who fitted it didn't use a sealant by the way.
Also, might the fact that the bottom portion of the plastic cam belt cover is missing be making things worse? Mind you, I think it was leaking pretty badly even before that parted company completely so I guess not....
Old 25-11-2011   #5
Trader Rating: 5
Cam belt cover missing won't make any difference. Opinions differ as to their utility!
Yeah, the gaskets don't last forever. The breather is the pipe (3/4" or so) near to the filler cap which goes to the airbox. There's a little flame trap in there that gets clogged with oil over the years. Leaving it for half an hour in white spirit or degreaser and then flushing water through it (off the car, of course!) usually renders them as good as new.
M12 fund 20
Old 25-11-2011   #6
You might be interested to hear that my garage's diagnosis was that the oil needs changing again, as the old oil has thinned and therefore finds it easier to leak through the gasket. Anyone agree with this?
Old 25-11-2011   #7
Trader Rating: 5
If the oil has thinned that much, there's something seriously wrong with the engine! Nah, horlicks, they're trying to fob you off.
M12 fund 20
Old 25-11-2011   #8
Palmerino has donated!
Definately agree with Fingers, this is why I love having a family friend mechanic, none of this nonsense. Sorry for you being c*cked around mate :/
My Cinqy -http://www.fiatforum.com/members-mot...ml#post2866014
Wanted:1.2 8v engine
Free stuff... Who wouldn't?
Palmerino is offline Reply With Quote Quote
Old 25-11-2011   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
I bet they overtightened it.
They should only be on just a bit more than finger tight.
D
Old 20-12-2011   #10
But how come I went from June this year to November without a noticeable oil leak? It always seems to be the cambelt side of the engine where it's worst, too - never seems to leak anywhere else.
Old 20-12-2011   #11
Trader Rating: 5
A few possible reasons. First is that, as with all things, it takes times for leaks to develop. Second is that the ends are where the cover changes section. It's harder for the gasket to work effectively there. Third is, check that the leak is from the cam cover and not from the pulley side crank seal.
M12 fund 20
(T) rocker cover oil leak johnsoncarper Punto (Mk2/2b) 32 28-01-2015 14:03
(G) Mk2 punto rocker cover oil leak johnsoncarper Punto (Mk2/2b) 4 31-12-2009 08:48
(G) rocker cover leak can be caused by the insufficent sized oil breather pipe? Raducu Punto (Mk2/2b) 3 25-05-2009 19:17
(T) Oil leak - Rocker cover? or what? Mdeko Punto (Mk2/2b) 17 05-05-2009 21:27
(T) Rocker cover leak !!!!!!!!! punto55 Punto (Mk2/2b) 2 26-02-2006 19:23
