Hello,
I am Peter from Poland. I started read this thread almost a year ago and I want to thanks woj for his hard work.
I have Seicento sporting 1,1 SPI with Cat Cams 270° and there is similar problem like motoguzzinix described - to much fuel on idle...AFR is about 11.
Thanks to wojs xdf I pulled up idle to 1100 rpm and I advanced a little bit (1,0 - 1,5°) ignition idle/closed throttle. That improved idling but it is still to much fuel and I try to find right map(s) to correct this.
Concerning last pasto post - I think there is problem with slowly raising idle rpm after start, because engine is overflooded. I can observe similar behavior of my engine from time to time...
I think that you found new interesting maps. I modified xdf to fit B1DE.bin and I puted these new maps into tables. Unluckily I dont't have emulator, so it is difficult to me to verify changes.
Regarding map F195 I am not sure - I found one rpm map (16x1) but it starts from address F184.
