- Oct 20, 2007
- 4,940
- 744
lol i will when i come to do it. ;-)
i may be looking at the wrong post but did aaron and emma not use an mgf front arb, i am wondering if i could use the standard cinq sporting arb with out having to cut it and weld
I want a friend with a pipe benderI got a friend that has a bar/pipe bender, could just take some measurements and tell him to bend one to suit
Ming
guys. if you put a front cinq (or front any car) arb on the back of the cinq it will be far to stiff.
ive aquired plenty of arbs from lots of random cars and some of them look to be an easy fit on a cento. but they are all far to stiff.
what you can do (what im going to try)
cut the middle out of the cento arb then replace it with a tube. (this with increase the stiffness of the front arb)
bodge a front arb onto the back of the cento. make sure the drop links are positioned for maximum leverage (try make the position adjustable) as to limit the effort from the bar.
if its still to heavy then take grinder to the arb to make it thinner.
but still dont expect this to turn your car into a mini. it would take a lot of track time. and just because a car feels like it rolls a lot, dont mean it handles crap. the suspension is still keeping all the wheels down. with a arb the body will still want to roll but the arb will try lift the inside wheels, this will leave you with actually a lot less traction
So if i were to use a thinner bar to make the rear ARB, then it should fine ? (i.e. not too stiff)
Ming
You sure you just havn't lower the centre of gravity of your seating position ?(as i feel the same as well in my other cinq)
ming
thats what i ment
standard seats are really high which dont help body roll at all
