- Oct 20, 2007
- 4,940
- 744
yeh. each to there own. im not a all out speed demon all the time, but i do love a bit of quality music. not loud just quality. so still going for the install. and it wont matter soon anyway! lol
lol. as you dont have rear struts i dont see a point in a rear brace. purley asthetical in my mind. but a rear arb would be good. still going to get a rear bar but i dont think there is going to be any flex when ther is a solid axel running across the base of the car.
Hmmm not exactly true, as the rear seats is just really just a bar with the form above. It does strength the chassis in some sort. If you do remove the rear seat, have a bar or some sort made up.
Or cut the rear bench up and use that bar!
Ming
in the words of a great man "POWER" lol if you aint guessed i'd rather have speed than tunes but i will be keeping radio and the front speakers and mounting 6x9's in the rear quaters and no false floor or sound deadening as it weights far to much and will slow the 1/4 mile time down
totally agree with that, my first sei sporting was fully stripped and i swear i couldn't tell any differencethe bar at the bottoom? thats about 5mm thick? that surely isnt strong enough to stop any chasis flex and as the rear seats are also split seats there is no support at the top of them. when i go off a kerb a wheel at a time you can hear the back creak so i dont think the seats do anything. if it was a solid bench mabee yeh.
https://www.fiatforum.com/cinquecento-seicento/166019-cinq-abarth-project-1-4-16v-6.htmlJ333EVO said:The rear anti-roll bar is a modified 19mm anti-roll bar from the front of an MGF shortened and welded together.
Its held in place with front Cento anti-roll mounts and bushes on custom made mounting plates welded to the rear beam.
It is then fixed at bottom with Lancia integrale EVO1 rose joints (any rose joints would do but had these at hand) with custom made mounting brackets fixed to the bottom damper bracket, this will be further modified so the bottom of rose joints is at least in line if not higher than bottom of the damper to give better road clearance.
